Proper way to flush oil cooler?
2.4K views 10 replies 10 participants last post by  benson8277
So Turbos go on next week, and this is the last thing I need to do to prep for it.
I got this stock oil cooler used as a package deal with some other TT stuff. It looks to be in very good shape, and as far as I know came from a wrecked car that ran fine.
However I'd rather be safe then sorry, so does anyone have any suggestions on the most effect way to flush out a oil filter??
I was thinking maybe spraying/filling the inside with parts cleaner, and then using a air gun to try and blow it all out, then maybe fill it with fresh oil.
#2 ·
Kooler Kleen?
That is about all I know of. Then you follow it up with air. Then maybe run some oil through it. Run it into a fine strainer and make sure no significant debris comes out.
Flush it out with petrol to clean then dry it then put some oil through it..
#9 ·
Just flushed my cooler on a whim, started thinking about how important it is to get new turbo oil lines after spinning a bearing, but hardly anyone mentions the oil cooler. I blew it out with air first. A bunch of greenish oil/fuel/coolant stuff came out. I then pumped clean oil into the oil cooler and blew that out with air about 3x until it was clear.
#10 ·
My method isn't for everyone, as everyone doesn't have a solvent parts washer. I hook the brush hose directly to the cooler and let it flush for a considerable amount of time. I also reverse the flow several times, and tap the entire surface with a large plastic screwdriver handle do break loose any debris. I follow up by blowing it out with air.
