Old 01-20-2008, 02:34 PM   #1 (permalink)
Supporting Vendor
Trader Rating: (8)
ray pampena Level 1ray pampena Level 1ray pampena Level 1
Default 3.5L 6G72 this is what im building for my car!
how would you guys like an engine that keeps the block you have, fits in the car with no 74 conversion, fits all of you turbo components, and has no hood clearance issues?
its also super strong and (stronger than a 3.0 and just as strong as a 74) and its not my billet crank stroker kit.
ive played with these for years but wanst a fan of cutting the mains down on a 74 crank to make it fit. i felt it would make a 74 crank as weak as the 72 crank (which is strong enough for 99.9% of the forum)
ive come up with a new technique that KEEPS the stregnth of the 74 crank and still fits it in your 72. a crank is only as strong as the area of the smallest cross section. in the corners of the mains, stock cranks are rolled to a smaller diameter for cost savings but thats where the cracks start.
i have a new way of machining the large 74(or 75) cranks down while leaving these corners untouched so the diameter and overlap are the same as a stock 74. (leaving a large radius like a race crank) this will use custom main bearings to make this work and makes this design as strong as a stock 74 can be! (which is stronger than a 72)
so this is the engine im building for my car. it has the stregnth of a 74 with the nice fitment of the 72!
3.4-3.5 depending on bore or 3.5-3.7 with the 75 crank (more work required to fit)
the full shortblock is $6500. these cranks are coming out AWSOME and STRONG! there is HUGE cross section area... WAY more than a 3.0!
a fully balanced rotating assy, pin fit and all with custom pins.. all machine work done ready to drop in your engine is $4995. you will need to do light grinding to your block.
a NEW crank, custom ground to our stroker specs, balanced with mallory, ready to use with YOUR rods and OUR pistons $2164
take away all the balance work and get the above for $1625 then you need to have it balanced yourself.
it uses my custom 6G72 rods with the wide small end.. $1095 (you can use your rods too)
custom pistons that ONLY fit this engine $795
custom tool steel pins we have been using for quite some time on our other engines $185
THESE PARTS ARE NOW ALL ON THE SHELF AND READY TO SHIP!
Ray
PAMPENA MOTORSPORTS
631-566-5959 631-676-2448
getrag rebuilds and modifications
pampena motorsports race engines, strokers
custom CNC parts
dyno tuning, street tuning. ask me about traveling to tune
pampenamotorsports.com
years of fast cars and excellent feedback!
ASE master tech, ASE advanced level specialist, Diamond Pro Mitsu master tech
specializing in building FAST STREET cars
ray pampena is offline   Reply With Quote
Old 01-20-2008, 02:37 PM   #2 (permalink)
91vr4n00maxima's Avatar
Drives: slow 97 VR4
Trader Rating: (20)
91vr4n00maxima Level 291vr4n00maxima Level 291vr4n00maxima Level 291vr4n00maxima Level 2
Default Re: 3.5L 6G72 this is what im building for my car!
pure buttsecks.
91vr4n00maxima is offline   Reply With Quote
Old 01-20-2008, 02:45 PM   #3 (permalink)
Everclear Aficionado
NudeFury's Avatar
Drives: '93 VR-4
NudeFury is an unknown quantity at this point
agreed; and im not even a fan of buttsecks!
Having a fast front wheel drive car is like coming out of the closet, you might surprise some people, but in the end your still gay
NudeFury is offline   Reply With Quote
Old 01-20-2008, 02:53 PM   #4 (permalink)
3KGT2NV's Avatar
Drives: 1994 3kgt vr-4
Trader Rating: (49)
3KGT2NV Level 13KGT2NV Level 13KGT2NV Level 1
I would be down for that kind of buttsecks but I just rebuilt my engine and am in the process of paying off last years buttsecks already.
3KGT2NV is offline   Reply With Quote
Old 01-20-2008, 02:54 PM   #5 (permalink)
Finally home!!!
Drives: 92 VR-4, 95 RT/TT
Trader Rating: (29)
Tujin is an unknown quantity at this point
So any speculation on what type of numbers it could make before the crank starts to flex?
92 SL - Brother's DD, suddenly my problem again
87 Starion - Exhaust, MBC, SAFC
92 VR-4 - Forged 2nd gen Crank, Shot Peened Rods, ROSS pistons, UD pulley, Poly mounts, TD06SH-25Gx2, Tial 40mm external wgs, MAF-T Pro in Speed Density, PTE 680cc injectors, CX FMIC, Walbro 255 + Bosch 044 Pumps, Spec Stage 3+ Clutch, Tial BOV
95 R/T TT - Intake, Exhaust, gutted cats, solid motor mounts, RPS 6 puck clutch, HKS SSQV. Running wastegate pressure for now
Tujin is offline   Reply With Quote
Old 01-20-2008, 03:05 PM   #6 (permalink)
Crap - you got me!
GTO Assassin's Avatar
Drives: 1993 Mitsubishi GTO
Trader Rating: (33)
GTO Assassin Level 1GTO Assassin Level 1
Damn you Ray Pampana! Hopefully buy the time I'm next investing in an engine, these will be readily available to me.
Scotty
GTO Australia - W.A
GTO Assassin is offline   Reply With Quote
Old 01-20-2008, 03:07 PM   #7 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1992 Stealth TT
Trader Rating: (51)
Forest Gump Level 1Forest Gump Level 1Forest Gump Level 1
sounds great. Can't wait for pics of the machining.
Edit: has anyone looked into boring the mains on the block? would it weaken it to much or cause oil pump problems?
Power:13Ts, 550s, SAFC, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, IK24s
Best 1/4 12.62 @ 111.9 2.0 60 FT Best 1/8th 8.00 @ 87.24 1.80 60FT
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G front brakes AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, F&R Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps, Scanmaster3, AEM UEGO
Forest Gump is offline   Reply With Quote
Old 01-20-2008, 03:08 PM   #8 (permalink)
Supporting Vendor
Trader Rating: (8)
well the 74s been doing great in the flex dep. this is as strong as that but it fits. this is the best choice for me since i wont have to re engineer my whole car.
Old 01-20-2008, 03:10 PM   #9 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Awesome Ray. Just awesome.
R.I.P.
Old 01-20-2008, 03:10 PM   #10 (permalink)
Finally home!!!
Trader Rating: (29)
Same here. A bigger block is just not an option for me. This is great man, I'll def be giving you a call next year when I'm done with deployment.
