flow maps, pressure ratio and air flow
1.5K views 16 replies 6 participants last post by  silky
#1 · (Edited)
ok so I am looking at flow maps to decide which turbo I want to go with. What I am a little confused on is how to find the pressure ratio and air flow I need.
pressure ratio: From the reading I did I found that to get the pressure ratio you take the normal air pressure of your area (14.7 for me) and add it to the desired boost you will run (say 30) and divide that by 14.7 to get the pressure ratio. So it would be 44.7psi/14.7 = a pressure ratio of 3.04
Air Flow: This is where I get a bit lost. Calculations > me!. Can anyone help me with this? I just need to know the air flow for a stock 6g72 in say 75 degree f. weather. I did some calculations from a site but they don't feel right to me. But here they are:
181 / 3456 x 5800 rpm x .85 VE. x pressure ratio = 784.9 cfm or ~54 lbs/minute
does this seem right? Does a stock 3 liter flow 54 lbs? This formula seems weird to me. Where did the 3456 number come from? does a stock 3.0 really flow 54 lbs/min?
thanks for looking,
john
edit: if this is right it puts the 6g72 right at the top of the gt4088's efficiency island, no?
http://www.turbobygarrett.com/turbo...bobygarrett/images/catalog/Turbochargers/gt40_images/GT4088_703457_2_comp_e.gif
#2 ·
The math is fine. The 3456 converts the cubic inches to cubic feet. Can a 3.0 litre flow this much air? At some point the heads will be a restriction and would require possibley more boost than your desired pressure ratio to flow 785 cfm.
Are you planning to run a single?
#4 ·
Yes, I am going to be running a single.
Mark: I was just playing around with numbers. This car will be a full street car though. Do I really need to rev higher than 6000rpm? I am not planning to build a beast! I am aiming for ~550 whp. I know, I can make that with 16g's but everyone has 16g's :p/
#14 ·
you want to stay in the hp as long as possible, 5800 is only going to be about for 2k rpm. that is not going to make very fast. you will be for one shifting to fast. you will atleast need to go to the stock rev limiter of 7300, i would personally get springs in the head and go to 8k and 8k is safe, some go to 9k but 8k is very do-able with springs.
that will leave you in your peak power band for about 4k or more depending on the turbo. that will make you fast. and shift less.
#10 · (Edited)
#12 ·
do changes in turbine A/R affect compressor maps? ie would the map change if you went from an a/r of .81 to say .91 or whatever?
I am basically just looking for a turbo to make in the neighbourhood of 550 awhp but with minimal lag... I would be happier with a turbo that has a healthier low end and falls off in the high end, and from my readings I assume that means I would want something with a lower turbine a/r?
#13 · (Edited)
The compressor map wouldn't change, but your engine's demand lines might (VE).
Correct, but turbos capable of doubling the stock configuration's power output will exhibit considerable lag regardless (i.e.- "minimal" will be significantly more than stock).
#15 ·
im currently running a t76 on a P trim turbine, divided exhuast housing .84 a/r. it spools right about 3500 but doesnt really pull hard till 4k. so when i install springs ill shift at 8k. and that will give me a car cable of 700whp and 4000 rpm of straight pulling and hauling ass. ( and its only journal bearing not ball bearing ) well for now :D
you ofcourse dont need anyhing that big so about a 66mm turbo will do your job.
#16 ·
sound performance has a "billit" t-71 that hits full spool (+30psi) before 4k rpm. that same turbo has put down well over 800whp on supras. with the turbos that have come out in the last few years lag isn't really an issue with our motors unless your trying to get a car over 900whp.
