I have a cracked water pump housing. I have only been able to find the housing for a sohc. Anyone know where I can find one for the dohc? it's a 95 if that makes a difference. Thanks!
The water pump. Aftermarket pumps are sold without the housing. We found out the housing was cracked and glued together after we took it apart. I Just havent been able to find the housing for it. I can find them for the sohc. if you type in 3000gt water pump housing in google, it only comes up with ones for the sohc
Oh, I see. I've never had one apart before. If it works, there was a almost new oem pump on here for sale. Its taken apart also. Its for a DOHC. You may check it out.
The problem is you did not ask for a complete pump. Go to "cherryhilltriplex" and get a complete unit. around $125.00. I have also used other brands and I can tell you "Don't".
