In my "replace way more than I need to in the suspension" project, I've got new trailing arm bushings - the ones that are towards the front of the rear subframe.
In the exploded parts diagram:
It looks like if I disconnect the vertical bolt going through (part 17/18) that I can take off the knob with the bushing in it (15/16) so I can replace the bushing. This would be much easier on the press anyway and not require me to remove the entire trailing arm. Before I try this, is there a reason why this won't work as well as it looks like it should? 176k mile car.
