I am used to seeing my oil pressure light be glowing red when the ignition is in the ON position or while cranking and it immediately goes away after starting.
The fuel pressure regulator issue 2-3 weeks ago where I had loooonng cranks caused the oil light to flicker quite a lot. Do you think it burned out? How would I go about testing that circuit? Can I use the wire at the oil sending switch to test for continuity?
It is the original. I ran some engine restore additive through the oil pan when I bought it months ago. Maybe the little particles gummed it up?
