I know many people on here have the IPO fuel pump hotwire kit. This kit uses a relay, 10 gauge wire, and an inline blade fuse holder with 30 amp fuse. This inline blade fuse holder cannot handle the electrical demands of the fuel pump. The current draw will melt the fuse holder and could potentially start a fire. This may be caused by poor connection between the fuse and the fuse holder which causes isolated hot spots and arcing. There have been several others who have had a similar issue:
http://www.3si.org/forum/showthread.php?t=364717
http://www.3si.org/forum/showthread.php?t=360379
My fuse holder recently did the same thing in that it had melted internally. It was making electrical contact even without the fuse in place. If you don't inspect for this by removing the fuse, you won't even know it happened. So, I urge everyone who is using inline style fuse holders for their fuel pump hotwire to inspect for any melting. I suggest replacing the fuse holder with a higher quality car audio fuse holder, which can be purchased for ~$10 at Best Buy or any car audio shop.
I believe it would be in the best interest for IPO to recall these kits before he is sued when someone's car catches on fire.
