Power windows not working after rebuild?????
207 views 7 replies 3 participants last post by  riskeavr4
I just took my baby for a test drive today and my rebuild was a complete success:D ONe problem though, No power windows:confused: I did absolutely nothing to the inside wiring and everything on the outside was hooked up correctly. Power doors still work so I know it's not the switch. Any ideas???
#2 ·
OK I've double and triple checked every connection, Is there a fuse for Power windows? It doesn't list one in the owners manual.
ttt
Neither side works and I know to disengage the window lock. ;)There has to be a fuse or something that is breaking the circuit. The manual says something about a saftey switch that engages if you make the window go up and down too many times to fast. These window motors haven't run in about 7 months and they worked fine before my engine overhaul. Could I have accidentally shorted something to the window that could have filpped this "safety switch" or have a loose ground or something? (checked but didn't double check) anyone familiar with the schematic for the power windows?
ttt
Come on guys, I'm not trying to sound like a dick, but someone out there has to have run into this before
#8 ·
Power comes from Fusible link #9 30 amp marked WDO in the under hood box.
