Will I need the 3SX Adjustable Rear Control Arms? They say that 3kgts commonly have problems even if you install a tein system...I'm not planning on lowering btw, so maybe that affects things...Thanks guys -_-.
If you cannot get rear camber into spec you need them... Usually needs to be 1.5" or so lower than stock.Silvertsiawd said:I have the Tein flex coil overs, I was never told I'd need to change the rear control arms, could someone explain this for me?
-Dan
I get that a lot with my tein flex - its kind of scary when it happens the first time .95wildtt said:Anodized,
I go out of my way to AVOID the really bad roads as I get bounced off of the headliner...
John
MadMax IL said:well, avoiding known bad rough roads is great - but yesterday during a "spirited" ride thru some twisty mountain landscape it got reall bump & I was literlaly launched out of my seat, bumped my head on the ceiling and bounced bounced bounced til I slowed down almost to a stop.........thank "insert your god here" this all happened on a straight away, if it was on one of the turns, I dont want to even think about it.
Can it be that the Tein are great for a well upkept track only?
Ive lost confidence in the meantime until I work out the suspension , either figure out whats wrong with my Tein Flexs or buy something else that works better (at this point I am missing the stock shocks)
:sad:
only slightly softer or you have to get them revalved.... probably not free either. since it looks like they throw every coilover kit together with the same parts no matter which car....iceeagle2102 said:You can order different, softer, springs for them also. i haven't done it yet but i am planning on it later once i get the car running.
Grant
"Off Road" heheRed-SL said:If you read the owners book it dose say the suspention is for off road or show use only. Ha who reads the instructions.
