Headunit Light
535 views 6 replies 4 participants last post by  greenpanther
Well as the days come to a end intill im a stealth owner i ahve relized that there is a small problem. On the radio the light is dimed. You can onyl see the light at daytime but it is still very light. It is a stock stero sysytem. I also looked in past posts but all directed into replaced headunits not stocked. All respones are appericated... Thanks Anthony
What do you mean that you can only see the light during the day??? It would make sense that it would be easier to see it in the dark. Also which light are you talking about?? The whole illumination or what??
I've had a similiar problem off and of since I bought the car a year ago. I usually just have to tap the head unit and the lights start working again. Seems worse with cold weather. I'm thinking it's probably a loose connection, but it doesn't really happen to me enough to investigate further.
Good luck.
Chris
