Greddy Emanage Ultimate- Speed Density Package
4 reading
1.9K views 39 replies 10 participants last post by  LeMoN1438
#1 · (Edited)
Greddy emanage ultimate ~ sold
Greddy 4 bar MAP sensor/harness ~ sold
A/F harness ~ sold
USB cable ~ sold
91-93 boomslang plug and play harness spliced with Greddy Fuel injector adapter (NO CEL) ~ $215
GM Air Intake Temp sensor/harness ~$50
Barometer signal adapter ~ $5
LC-1 Wideband ~ 180
Intake coupler/adapter ~ $5
All prices include shipping, not paypal fees.
Would you be willing to part out some of the stuff?
Save
I will buy it if you will help install and tune it. I could come to you. I don't need all of the parts, but we could work something out.
Save
#8 ·
Well thats what the wideband is for, Autotune function. As for the install it plugs directly into the ecu with the boomslang harness, only a power/ground needed.
#9 ·
You are dealing with a tuning moron. I have had the emanage right now for over 2 years, and my car barely runs. I have an AEM wideband O2 currently installed. I already have a bunch of the other harnesses installed as well. To be honest I am not even sure which ones as I didn't install the emanage myself.
Save
#10 ·
Well basically once you calibrate/install the wideband. You set the targeted values for the AFR into the emanage and it will automatically build the table for your setup. Using a palm datalogger also helps to correlate the afr values and monitor knock.
Refer to the Emanage Ultimate thread in the ecu tuning forum.
#11 ·
Yeah, sure sounds easy. I don't know why I am having a problem tuning it. Probably just not taking the time to learn. Don't you want all of the targetted values to be like 12.7 or so approximately?
Save
#12 ·
Those values are a bit lean even for race gas, there will be diff targeted value for part throttle, cruise, wot, etc. Contact me on aim for more information, lets try to keep this thread focused on the selling aspect.
#16 ·
I will give you $500 for the boomslang harness, the ultimate and the map sensor.
Save
#19 ·
If it does get parted out, I'd buy the barometer signal adapter if that refers to the resistor setup you have to fab, and if its made well.
Save
#26 ·
I'll take the barometer signal adapter.
Save
You have insufficient privileges to reply here.
