Well here is the deal for one i do not own a stealth or a 3000- BUT- i have been looking into the 6g72 motor and not alot of people know about it its seems to me- so i thought to come here to ask you all seeing that you all got some varient of the 6g72 motor.
Now i am looking at buying a duster or shadow for the complete and utter sleeper affect- i got a fiero that is soon to have a 327 in the back of it for speed the 327 dynoed at 350 crank hp so that should be putting me in the low 12s.
The early 90's dodge shadow ES had the 3.0 6g72 motor and had an option of a base 5 speed.The veriosn of the 6g72 it had was the sohc. So for one can i just swap over the dohc top end to the sohc or will i need an entire dohc engine for the impossibility of this?
Then my second question would be if i need to swap in the enire dohc motor is that hooked to a fwd bolt pattern so it WILL work with the tranny in the shadow homalogens?
Next is now that i have gone to dohc in one way or another- in the dohc twin turbo motor are those different pistons or a different bottem end in anyway then the sohc or the NA dohc 6g72?
If it is different- is it all swapable over to the sohc?
If not where would you recomend finding forged pistons/rods/rings/bearings to run say 15 pounds at the engine.
Thank you to anyone that will probide their time and knowledge into this matter.
