Will Rockford Fosgate P2 Punch 10" subs fit an APEJOB'S BOX?
1 reading
3.4K views 5 replies 3 participants last post by  soundeng
G
Here's the link-- I really want the p2 fosgate punch series.. mounting depth says its 5.6" and apejobs box is 5.5"
WILL THE SUBS FIT??
http://www.rockfordfosgate.com/prod...rockford/ModelInfo/ModelInfo.asp?ItemKey=10065590&CategoryDesc=Punch Subwoofers
**ALSO, which apejobs box is better? The one ten/amp combo/ or the 2 10" sub box?**
2 10" box:http://cgi.ebay.com/ebaymotors/Dodg...ub-Box_W0QQcmdZViewItemQQcategoryZ38647QQitemZ8006319425QQrdZ1QQsspagenameZWDVW
1 10" box/amp combo: http://cgi.ebay.com/ebaymotors/Dodg...ub-Box_W0QQcmdZViewItemQQcategoryZ38647QQitemZ8006947069QQrdZ1QQsspagenameZWDVW
#2 ·
no, you will be .1" too large. What you could try to do, is set some sort of spacer to raise the outer lip of the subs up, so they clear. I would also check out the cubic space that the subs require.
i believe the apejob box is 1.1 cu ft combined. which is on the lower side for abox
I have his box but I put in 8" subs - his box is 1.1 cu so what was said above is true-if you go to crutchfield.com they tell you how much airspace is needed for each sub -if you add the air space neede for the two 10' subs - it will prob be more then 1.1 cu.
Your real questions should be - Do I want a box to fit behind the seat? -or Do I really want 2 10" subs in my car? Since the depth is already an issue -that's one strike right there.
The box is awsome and fits perfectly - just do some math and take your time to decide what you really want out of your system.........
:cool:
