181 - 200 of 347 Posts
I've designed this touchscreen scantool to work with all year model stealth / 3000GTs, including your 1994, and also any cars that had their ECU replaced with an incorrect year model. So in short, yes it will work.
Whats it cost And I'm gonna need this cause I just upgraded a lot of stuff and I'm throwing on a eaten M90 and I have 2 turbos I'm gonna compound and gonna compound and run compound turbos with the super charger
Recently got one from eBay, hoping you might be able to help troubleshoot.
1994 Dodge Stealth RT 5 speed - I don't seem to have communication with my OBD2 port. I've tried using my trusty bluetooth OBD2 reader and also your scan tool, neither can establish a connection. Do you happen to know any tests or troubleshooting tips for checking the OBD2 port?
Save
Discussion starter · #200 ·
1994 = OBD2 style port, but no OBD2 communication, it communicates as MUT. Did you remember to go to configuration menu and change ECU protocol to MUT ? After that is done, move the switch from OBD1 to OBD2. Ignition key must be set to RUN position and not just the first ignition key click.
You have insufficient privileges to reply here.
