where is it, i followed instructions for the dohc but i couldnt find it?
If your a wuss like that girl houdini youll use channel locks. If youre a man you wont need em.houdini said:To get the hose off of the pcv valve end, take a shop cloth and wrap the teeth of a pair of channel locks. Twist hose back and forth to break it loose, pull off hose. Don't get a cheap FRAM PCV valve. They are plastic stick with the metal kind. Also don't over tighten the valve putting on the new one.
Good luck!
I took a pic for ya real quick.
