181 - 200 of 372 Posts
Thanks for the fast response, when should I pay the deposit?
1:vlmora - Kit 3, Option 1 (Black), Option 4 (Kevlar/Teflon) and an FMIC with DNP pipes
2:bigmandannyd - Kit 3, Option 1 (Black), Option 4 (Kevlar/Teflon)
3:1fstascar- Kit 3, Option 2 (blue), Option 6 (kevlar/teflon)
Room for a 4th? ;)
full kit, Teflon BLACK cable(8an or whatever), all fittings, fuellab 828 filter + 6micron element, if you can not bother to include any special mounting for this as I'll be mounting it on the stock battery location all black fittings...paying extra is not a problem, your time is well worth it buddy...BLACK fuel rails...no writing or anything if possible...
if Possible Black everything...anything not black I'll sand blast and matt black anyway :) gimmie a total and we can rock n roll
Discussion starter · #184 ·
Coolbeans! Always room for another, just add yourself to the list. My cnc guy said my rails are in production so I should see them soon.
My setup has the FPR by the thermostat, moving it to another location won't work really with the stainless tubing.
From the sounds of it your looking for the following with everything BLACK, sorry but the fuel rails are anodized clear. I can ask my supplier how much it would cost to anodize one set Black but no promises
Kit #3, Option 2, Option 5, Option 7, Option Fuelab Filter #82832 (5" -8an w/6 micron fiberglass element) Will this filter fit in the oem location? I only tested the shorter one.
Once I have the fuel rails in my hands I'll be asking for deposits.
Room for a 4th? ;)
FPR in stock location is A-OK dude, only thing I'm after is the ability to move the fuel filter around and for the larger 828 filter no problem with the fuel rails, I'll just sand blast n paint :) problem gone.
I'm assuming that if I need to stuff around with the fuel filter you can supply me some extra teflon braided fancy pants cable and I can just cut it to length? just have some flex from pumps to filter then more flex to whatever the filter connects to :) if I can still have the stuff to do the return line that would be very helpful though!
Forgot to post the picture of the engine bay. So here it is:
Thanks once more for an awesome kit.
Save
Discussion starter · #189 ·
That' looks HOT HOT HOT!
Suggestion......tuck that O2 connector under the injector cover. If the cover has the plate under it just remove it and the connector will fit right in there cleaning it up. Also noticed you have a additional fuel pressure sender on the FPR. You can get you an adapter to move it by the fuel filter, same as the one on the front rail only -8an.
Kit #1 - Custom Fuel Rails (Clear Anodized) w/steel -6an adapters - $175
Kit #2 - Custom FPR Bracket (Fuelab Only!) - $46
Kit #3 - Custom Fuel Rails, Custom SS Tubing, FPR Bracket - Sourcing your own Fuelab FPR and EARL fittings - $431
Kit #4 - Custom SS Tubing, FPR Bracket - For your existing custom Fuel Rails (EK2, etc) Sourcing your own Fuelab FPR and EARL fittings - $266
Option 1: All fittings from Y-Block (-6an feed adapter at y-block and -4an return (oem) - (Blue Fittings $243) (Black $257)
Option 2: All fittings from Y-Block -8an feed adapter at y-block and -6an return - (Blue Fittings $220) (Black $234)
Option 3: -6an Braided Hose to oem filter w/adapter to oem filter
Option 4: -6an Braided Hose to -6an Fuelab fuel filter w/adapters to oem fuel line
Option 5: -8an Braided Hose to -8an Fuelab fuel filter (no options for tank to filter) $115
Option 6: -8an Braided Hose to -8an Fuelab fuel filter w/ adapters to oem fuel line - Hose $115 / Adapters and Bracket - $57
Option 7: Fuelab Fuel Pressure Regulator - $135.41 - COLOR?
Option 8: Fuelab Fuel Filter -6an 10 Micron Fabric - $81.50 - COLOR?
Option 9: Fuelab Fuel Filter -6an 40 Micron Stainless - $112.88 - COLOR?
Just for Reference.
I want:
Kit #3 $431
Option 2 (Black) $234
Option 5 (Black) $172
Option 7 (Black) $135.41
:D
I think this is right, I basically want the below...I know your not supplying everything due to variations in what people are running.
Teflon line to run from Tank to Filter (just enough length from tank to filter is fine + a few feet to work it around things)
8AN fittings to go on each end of above line.
8an black 828 filter + mounting bracket+10micron fiter (I know it will be more expensive than listed...just give me a price and I'll pay it no worries)
all components after filter...rails/fpr/guages/ss tube/everything that runs to return??
something around the $1,100 mark excluding shipping?
Looking at buying a set up soon, my cell is 325-829-8054, please text me. Need something similar to what 3sx sells, just looking at my options
Discussion starter · #193 ·
4: MichaelMR2 - Kit #3 $431, Option 2 (Black) $234, Option 5 (Black) $172, Option (Black) $135.41 Option ? Black -8an 828 filter + mounting bracket+10micron fiter
5: Boost4VR4 - Kit 3, Option ???? Black
6: DarkHeroKOTRAJ (For Mike that's in Iraq) - Kit 3, Option 2 (Black)
Thanks for the tips I will be cleaning up a few more things any ways, long story...
Save
Take me off the list, my car just went down and I have to drop some coin in it to get it running first. Sorry everyone.
6: CPTGTO - Kit #1, in all black, because once you go black!
Fix the list since some one took me off :p
7: DarkHeroKOTRAJ (For Mike that's in Iraq) - Kit 3, Option 2 (Black)
Save
hmm i Pmed Bob over a month ago so im somwhere in there..
Save
You have insufficient privileges to reply here.
