loud squeal when steering wheel is turned all the way.... how to solve?
9.9K views 8 replies 8 participants last post by  billvp
Okay, here's the full story. If I start my car up when it's cold, roughly 7/10 times it will make this real high pitched loud sqealing noise. I'm pretty positive it's the power steering belt. Anyway, once my engine is warm, it doesn't squeal... unless** I turn the wheel all the way in either direction once the wheel stops turning I can see the power steering pump lock up and then hear it squeal. I, figuring it was a power steering pump problem replaced the pump, and it still does it. Do you think the used power steering pump I got was bad too, or is there a different problem I'm missing. I'm open to any suggestions. It's really loud and annoying and I want to get it fixed asap. Thanks all!
#2 ·
well I've had that same problem before on several different cars. It was always the amount of fluid in the reservoir. but you said that you replaced the pump. I would try to put a litle extra fluid in and see if that works. and last I would see if there is anything clogged in the line... that could be the problem.
i wonder mine is the same as this though.... I heard a belt squeal at around like 40mph and from 60 on all fine.... weird... I drive local my belt always making noise.... does this sound like timing belt or something else????... only make the squeaking sound when I step on gas pedal.... the sound would come on..... whenever I accelerate... weird.... and I turn my steering wheel it would make a sound too... but my resevoir is full though for power steering.... weird...
#9 ·
I tried tightening my belt repeatedly, but it didn't help, it had to be replaced (power steering belt).
