Loud cooling fan problem/question...
154 views 7 replies 3 participants last post by  Steof
Well, my car ('91 Stealth N/A SOHC) was good for the first 2 years, but lately it has been giving me major/minor problems.
I finally got my car quieted down with a new generic exhaust system, but now my passenger side cooling fan is deafening me. It is CRAZY loud. Basically it sounds like a vacuum cleaner. I first thought it might be stuck on high, so I fooled it into thinking the coolant was hot. High kicked in and it sounded like a helicopter at take-off!
There is a problem with the cooling fan relay (or lack of one) and it is now shorted so that is stays on all the time (it was like that when I got it and replacing it with a relay did not work), but I don't see why that would cause the fan to be so loud. Is it on its last leg? Perhaps a fan motor problem?
I've searched the net and this board with no luck. All I can find is perhaps a bad fan clutch, but these cars don't have them from what I can tell. Anyone?
Also, if your engine temp stays normal at 30+ mph speeds and heats up hotter than Michael Jackson at a Boy Scout Jamboree at stops (and I KNOW the fan is running) what does that mean? (replaced bad radiator, thermo, and hoses 2 years ago)
Anyone have similar problems?
Hey Stealthee, thanks for the reply. Actually, the fan is shorted/bypassed to be on all the time (for what reason...i have no idea...it was like that when I got it). I rarely run the A/C and the button is not pressed in. However, when the A/C is on the driver's side fan runs, so that part of the system seems to work fine. I'm guessing I don't have a cracked head or blown gasket, since it doesn't smoke and I never loose any fluid. It only gets hot at stops after about 20-30 seconds. Any other guesses?
Yeah? Super, then. Wait, does a fan with bad bearings have a problem spinning? The fan does spin readily, no real tension in it. Would buying a new fan be a reasonable solution in your opinion?
Your problem sounds like a water pump issue...
So let's review --
When you are driving down the road and you have natural air flow through the radiator you have normal cooling/temp, but when you stop and idle the temp rises to hot.
I had that problem once, but for me it was radiator fan not on at all, which is obviously not your issue.
It sounds like you may be losing pressure in the cooling system, or the water pump is starting to go out. If the pump is not moving water through enough while at idle for the fan to subsequrntly take the heat away then the temp would rise. Also, this would explain why (even with a lower flow rate) that the extra air while driving would drop the temp.
You might try replacing the radiaor cap with a new one - but since you say you aren't losing fluid that is probably not it.
I would still check the pressure in the system and the water pump. Water pump is the strongest possibility in my mind.
#8 ·
Hey, rscultho. You get an F-. I most certainly did not want to hear about a water pump problem. That thing is supposed to be a pain with it being connected to the timing belt!
I'll check the cap and hopefully that will be the problem, though a bad cap normally means coolant loss, yes? Thanks for the replies rscultho and Stealthee. Mucho Appreciado.
