MitsubishiSpecialties said:
Hey Mike,
I can't drink enough coffee to keep up with your last post, give me a call if you want.
Something else i tried after getting bored with the mercy switch.................A co-worker of mine who was a computer engineer wrote some software for some kind of Chip to control a selonoid. He rigged it up with a pot (read potentiometer) so i could control the boost electronically (by changing the waveform applied to the selonoid)
It worked OK, but needed some fine tuning to work right. He got busy with work and we never finished the project.
Low and behold, 3 years later HKS came out with the EVC-EZ which is basically the same as what we were doing............
What I was saying was for launch just runs WG pressure...It's as low as I'm going to get and my alky will be triggered at 5psi as it always is. I have enough alky flow with one jet to get 12 psi and safe EGT's and no timming pull. Have the 1st MBC set at 12 psi. So the car when out of launch mode or WG pressure will boost to 12 psi and I have enough alky to cover that. Then have a switch that arms the hobbs valve for the 2nd alky jet. It will be set to come on at 12 psi. The secondary hobbs valve sends an electrical current once 12 psi is reached to the water selinoid to allow pressure to the second jet. I can also run current to a selinoid that allows pressure to the high boost 14-15 psi MBC.
So for daily driving I can just leave the car as is and I have enough alky and boost for 12 psi. If I arm the 2nd hobbs valve. At 12 psi my secondary hobbs valve lets alky flow to the second alky jet and at the same time feeds current to the selinoid that allows the highest boost MBC to come on line.
This way I could run WG pressure to launch. I would probably put a push button on the shifter and when it was down I would have WG pressure. I release it and have 12 psi and if I arm the "Ohshit" switch. Once I hit 12 psi I get the extra alky and boost to probably 15psi. You can't increase the alky for higher boost in a single stage because its too much alky at lower levels. I.E. Enough alky at 15 psi to have good EGT's gives you about 1400F at redline in 3rd gear @12psi. and the car hates it.
What I mentioned about MSD boxes. I wondered if anyone made one that sent out voltage at certain RPMs that could be changed and that could control these selinoids. So I could set the box to open a MBC at a certain RPM.
