Went to do a test drive and here are the pictures of my logger graphics. I noticed the same MAJOR SURGE PROBLEM. Jerks at about 2000-2500rpm and boost won't come up, it stays at 0. Code 14(TPS came out again, but thank God, code 41 didn't, so it seems the injector cleaning saved me from buying an ECU^^
For the timing advance, its REALLY OFF, I grounded the brown connector to put it in base idle mode, and I had about 22degrees against 17 with the connector not grounded. I had to change the female knock sensor connector because the last one was broken. I read that if the knock sensor is broken your timing advance changes when the engine knocks. Since I had no knock reading did I installed it wrong? I tried to find a way to test the connector, but couldn't find!! If anyone has an idea about whats going on in my car, any help is greatly appreciated!!! THANKS A LOT GUYS
