climate control display not showing but ac work!
7.6K views 6 replies 3 participants last post by  Lenny M
so the climate control display wont show but the ac will work! the guy i just bought it from said that when the cd player was installed it worked once or twice before then it stopped showing up? searched and came back with getting a new CC unit. would there be some fuses i need to check/wires? if so, which ones? im assuming your gonna point me to http://www.stealth316.com so ill check that out now. but im almost positive that its cd player related, thanks!
#2 ·
got the same problem, pls help us out guys! just happened with no cd player involved. searched but results aren't looking good, bottom line is may be getting new cc module. :(
#4 ·
I had the same problems and found out how to fix it.
You need to take that display box out of the dash, If you want a simple solution buy a new one from mitsu = $800 or used for about $100.
The unit can be fixed yourself however. Take out the little screws on the back of the unit and look at the board. Chances are a capacitor or two leaked and a resistor and some diodes blew. If you have an electronics store buy these blown parts, about $6 and sodder them in. I have fixed two of these units myself this way.
P.S. I think the range of the resistors and capacitors are kinda high so you won't be able to get them at radio shack.
macg23, thanks for the reply. if you can, pls give us an idea or step by step instructions on how to get the display unit out, are the procedures available on a service manual? thanks! :)
Sorry I can't help you right off the bat I'm away on business for the moment. I'll try to give more indepth detail when I have the time. For the most part I half assed the fix myself about 3 years ago. I just took out the display unit opened it up and saw a few component that were fried. I just soldered in the new components and it worked as good as new. I have a feeling that just like the ECU mitsu used shitty component that go bad after a few years.
check out this post for info on how I removed the display.
http://www.3si.org/forum/showthread.php?t=74447
