If I had all the parts below, would it be a big job to install? Would everything from a VR-4 bolt on to my car? Such as the manifolds and the oil lines? Have anyone ever done this before and what's the outcome?
Here's the list of parts for the TT conversion:
1.) Turbo ECU + harness or reprogram your n/a or FMUIgn. retard unit
Just the check valves, and a S-AFC to change the fuel curve
2.) Front rear pre-cats
3.) Pan
n/a pan drain line fittings as the VR-4 oil pan does not fit (the n/a block is more narrow)
4.) Gaskets/seals
5.) VR-4 " T" MAF boot
6.) 2 Turbos
7.) Down pipe
8.) Bigger exhaust piping or VR-4 exhaust
9.) Blow off valve
10.) Boost gauge
11.) Fuel pump as the n/a is WEAK
12.) 360cc injectors
13.) Intercoolers
14.) Intercooler pipes with ALL piping, but you will have to fabricate the rear I/C pipeas the n/a manifold has
a secondary butterflysolenoid that gets in the way of the VR-4 I/C pipe
15.) 2 Exhaust manifolds
16.) Y pipe
17.) Oil feed lines
18.) Oil sending unit
19.) O2 sensor housings front rear
20.) Thermostat housing as the n/a does not havecoolant line fittings for the turbos
21.) Coolant feed lines front rear
22.) Coolant drain lines front rear
23.) Oil drain lines front rear (custom) as you cannot use the VR-4 ones they aretoo short for the n/a
24.) Turbo inlet piping going to the MAF meter
3.) Pan
4.) Gaskets/seals
6.) 2 Turbos
7.) Down pipe
9.) Blow off valve
10.) Boost gauge
13.) Intercoolers
16.) Y pipe
17.) Oil feed lines
