Here's what i did today with Chai at his shop. Ran into a few issues, from which Chai had solutions for each... good times. Now I stop on a dime!
thanks Jojo for giving me the calipers, and to gabber for helping get me the knuckles, and dave for letting me borrow his steel braided lines so i could get these made perfectly... I appreciate it!
(this is mirrored here: 3000GT SL to VR4 Brake Caliper Upgrade
Today I finally got some braking power, and went from the anemic SL brakes from my NA Spyder to 1st Gen VR4 brakes (my spyder is a twin turbo conversion.... all the weight, plus the sppeed.... still small brakes). I don't believe 1st gen are as big as second, but these were free and available, so I went ahead and did it
First, here are the new stainless steel aircraft grade braided hose lines I will be using for my brakes. I will be selling these through deftracing.com, and they are top quality.
Here's what my cars calipers used to look like. I went for a honey bee look before to match the side lights, but the yellow was really hurting, and I wanted to go red.
Looking worn...turning whitish from the old darker yellow.
haggard.
I did do some prep on the new calipers though. First, i shaved the Mitsubishi name off with a grinder, and smoothed it out very nicely. I then used high temp caliper paint to lay several layers of red on it.
I also had something in store for the new caliper to see how it looked... and to match perfectly the rear logo on my car =)
Here's the VR4 knuckle installed. There's probably a real name for this part, but I don't know it if there is =)
You can see the old caliper hanging there too. This backing looks horrible. It doesnt matter, you dont see it at all behind the rotor.
Here's my new red caliper and the install of the new stainless braided line. Perfect fit
haggard.
