Ok, background... I'm running 680cc injectors with S-AFC. Before you say anything, YES I have enough adjustment with the AFC!
But what I'm finding is my timing is screwed up and I get 10-12 knock sums immediately upon boost. I'm currently tuned for .96 o2's and my EGTs are safely under 900c so it's NOT leaning out.
Also this is NOT "phantom knock".
Someone off-handedly mentioned to me "hell, the ARC-2 guys can run 720s with no timing problems"...
So I'm wondering HOW and WHY does the ARC-2 solve timing problems?
Does it have to do with the stock MAF? Are we fooling the ECU too much with the AFC? And if so, why does the ARC-2 work, since it also fools the ECU, doesnt' it?
The only thing I can think of is the improved air measuring from the ARC-2's sensors?!?!?
And if that's the case, do you guys think the new LS1 MAF and Translator mod could function similarly to the ARC-2 (at least as it pertains to helping with timing problems??)
I certainly could afford the $300 for the LS1 MAF, but will not be buying an ARC-2 anytime soon.
