rear strut bar install
1 reading
322 views 12 replies 5 participants last post by  VR4PWR
#1 · (Edited)
I'm trying to install a reat strut bar (Supermac) now with some difficulty. Do I have to take off the rubber boot and ECS connector or should the bracket slide over the boot? I'm having a hard time getting the bracket over the ECS wire and figured maybe I need to take it off. Thanks.
#9 ·
Boot is off
I just took it all out ans left it out. The boot doesn't really sit there perfectly anymore. Just leave them out and put the plastic covers back on you are going to have to cut those alittle to be able to reuse them too.
Eddie :mitsu:
#12 ·
on mine i just left the boot sitting ontop of the ends of the bar. didnt bother trying to see if i could bolt it back down. if you want to get the boot out of there your either going to have to cut it to get the harness out of it or take each individual wire and pin out of the connector, label where each 1 belongs, remove it from the boot, and re-install each wire in the connector. not that hard to do but i would reccomend just leaving the boot sitting there and trim the covers to re-install them.
