E85 Powered VR4?
1 reading
59K views 383 replies 62 participants last post by  Import Power
#2 ·
I have been running my EVO on E-85 for over a year now without problems, and will be doing the same with the spyder after I have all the modifications installed.
Main requirements to run E-85 are a very high flow fuel system since it takes 25% to 30% higher fuel flow for the same amount of air compared to strait gasoline, and an air fuel tuning method to adjust fuel flow without adverse effects on your timing curve.
Keith
#10 ·
Well, after the 1st it will get easier to start again! :) That is basicly what I was telling you to do on your own, by adding more gasoline to the mix it makes the blend easier to start in cold climet conditions.
Keith
some say that because of most unleaded running 10% ethanol, most fuel systems are safe for e85. The gas in e85 helps keep your fuel system from drying out. True, it will be harder on components, but most should last the life of the car. I also read that you should change your fuel filter with in a few weeks, because of sludge in the tank coming loose. I guess it's like running system cleaner all the time.
There are fuel system additives clamming that they help coat the fuel system for protection also.
#22 ·
#27 ·
but what about my car, its 15 years old? About how much more boost can you run with everything else being stock besides the injectors, fuel pump, and afc?
Your car can run on E85 perfectly fine, providing you have enough fuel pump/injector to provide the needed fuel. Ideally, I'd recommend a fuel controller that could control timing, unlike your SAFC.
As for how much more boost you could run it will vary car by car depending on modifications, but if you open up your exhaust by getting a downpipe/testpipe and gutting pre-cats you should be able to max out your current setup... then it is time to look into a better fuel controller, bigger IC's, and a larger turbo setup.
Think of it like this. Running E85 is like running 110 race gas. You can safely run significantly more boost without worrying about detonation.
#24 ·
before I moved to europe I ran a 4:1 mix of 91/E85 for a good 2 years
that bumped up the octane enough to run 20psi on DSM 13g's and DSM SMIC's without knock, my fuel mods were 580cc injectors and a hotwired walbro
I also dynoed 343hp/356tq at 18psi, the car had WAY more left in it, long story short (24 bent valves :eek:) I didn't have time to get it tuned very well before going to the dyno so I stayed fairly conservative
#25 · (Edited)
also the DSM shop that was near me when I lived in oklahoma made 650hp on straight E85 in a 1g DSM, and I think 575 on the 4:1 mix
it's good to see 3si finally starting to come around to E85, I remember when I first heard about it and started using it, everyone said I was going to damage my car and it wouldn't work and that it wasn't worth it, even though there were tons of people on other platforms (DSM's specifically) before me that used it no problem and saw huge benefits
#28 ·
You won't be able to run e-85 on the stock set up. You will need larger injectors and fuel pump.
I am currently running ~30% ethanol mix (3gal 110/2gal e-85) and my IDCs hit the high 90's.
I ran e-20 (20%,91 octane) to the NG this year and did a few pulls on the way and had no knock up to 18psi.
#31 ·
The kit looks like it's just a box that plugs in between the ECU and the injectors to lengthen the injector pulse. Unfortunately the stock fuel system will not be able to keep up with the fuel demand. You would still need a bigger pump and injectors.
#32 ·
A guy here just finished swapping over to e85 in his na-t supra. He is very happy. No more race gas :D
#34 ·
I've run e85 for a while now, with great results.... Yes, cold wether (CO) sux, and it's harder to start, but you can't have your cake and eat it too!!
That's just one of the characteristics of alcohol, it doesn't vaporize in the cold very well. So I crank a little longer....I can deal with that for the added boost. I also have a customers evo and an employee running it on his honda.
Cost wise, it's really nothing. You pay ~30% less, but you use ~30% more.
You do need something to tune it, I use AEM, but for whatever the mixture of e-85 vs 91 (or 93,104,110) you have to use a different tune. If you tune for 100% e85 then delude the mix with 91 you're going to be running rich, and may have too much timing for the lessened octane. Or if you tune for a 50/50 mix, and then run 100% you'll run too lean.
The way the stock "flex-fuel" vehicles get away with it is by giving the O2 feedback a quicker response time and more discression over the control. Since the O2's really read in "lambda" they're after a specific voltage, reguardless of the fuel type used.
This being said, depending on your system, and the controll alotted to the O2FB, you can very the mixtures without any problems. Stock ecu's usually have a +/- 20% discression. But if you stay close or past that 20% it will trip a CEL for rich/lean bank1/2 code...
UPP
#35 ·
not a single station has it in LA... amazing...
