AN fitting for stock fuel rail???
1 reading
1.1K views 3 replies 2 participants last post by  3srunner
dose the stock fuel rail uses 6AN fitting or 8AN? i need to buy one ASAP.
#4 ·
If you're using fuel rail adapters then it is most likely 6an. You can also measure the outside diameter of the SS line to determine what size fittings you are using.
If you're using -6an the outside diameter of the hose will be 3/8" if you're using -8an fittings then it will have an outside diameter of 1/2".
Hope that helps,
Shawn...
