3.0L Forged internals, Stage 3 Heads P&P, BC Springs, Ferrea +1mm Valves, Headlift Fix, Extreme Studs, Billet MHI EVO 16G's w/ 9 blade turbine wheel , IPS TD05 manifolds, AEM V2, Fluidamper Crank pulley, Gates Kevlar Timing belt, Spec Stg 3 6-Puck Clutch, DSR FMIC, PPE Pipes, K&N Type Airfilter with Dejon Pipes, SX Performance FPR, IPO Fuel Guage, 3" SS Downpipe, Borla Cat-back, 8AN - 6AN PTFE SS Lines, Fidanza Cam Gears, Greddy Type-S BOV, Hotwired Walbro 450lph Fuel Pump, 1300cc Injectors, AEM Tru-boost & WB 02 sensor, TIEN Coilovers, 300M Output shaft, 1 Piece PST CFDS, 3sx Radiator with Aftermarket Shroud/Fans, 18" x 8.5" Axis Hiro Rims fitted with M/T Sport Comp 245/40/18 tires
