Hi all,
I took out the intake and radiator and found out there are several connectors that are not connected to anything... Note that this engine was running with these connectors disconnected but I do want to figure out where they are supposed to go. (this is on a 1994 3000GT SL)
The first one that I would like to know is the left connector shown in the picture below. I know the right one goes to the IAC motor on the throttle body and they are on the same wiring harness.
The second one we have here runs across the plenum from the timing belt side to the throttle body side.
The last one I have here is the connector that is on the same wiring harness as the alternator connections.
Sorry that was a lot, but any help would be appreciated!
