1 - 4 of 4 Posts
· Registered
Got two seperate sections of wire which appear to have had the pigtails ripped off. The active aero motor plug is there, along with the fog lights so I'm trying to figure out what these went to. Any help would be greatly appreciated.
· Registered
93 NA ATX 3000gt DOHC
The two shredded pieces appear to both ends of a once continuous wire bundle, because wire colors appear to be same in both sections. Best I can tell of wire colors, looks like it might be wiring for right hand parking and turn signal light.
· Registered
It looks like the lower cut/shredded wire loom is run through the tow hook. That is not a factory wire routing technique. What is on the other end of the wire loom running through the tow hook toward the passenger tire?
1 - 4 of 4 Posts
