1 - 4 of 4 Posts
I need to know really quick if heads off of a 1991 DOHC will work on my 1994 DOHC.... both are non-turbo models... if they will what will i need to do on the swap??? thanx:(
Senior Fanatic
Don't know for sure but the CAS is on the head for the '91 and on the block for the '94. You would have to deal with that at a minimum.
Hell yeah they'll work!!! I should know. A few years ago my friend Gary had, um.............a little problem with his '95 SL. He needed some cam work done but prices were out there man for '95 cams. He bought a set of used heads off a '92 SL from some guy and we put them in over the weekend. Yeah we hadt to mess with a few thingsp-but not that bad. plus the heads were alot cheaper then his year for some reason. i see early heads go for like 400 used and 700 rebuilt so there cheap and around. we just changed over the heads for the hell of it so we would not mess with all the cams.
1 - 4 of 4 Posts
