1 - 5 of 5 Posts
· Registered
So I recently bought a used working digital stereo to replace mine due to some of the things on it not working. I had to make a harness to plug it in and it powers on and works, but it's having a odd power issue. It will turn on and then suddenly off at random. This did happen to my last unit as well. I'll post a video, im just not sure where to start diagnosing.
· Registered
1994 Mitsubishi GTO Twin Turbo MR
Does it fully reset or does the display keep it's settings/pre-configurations?
At one point when I had a bad alternator, it would fully reset/restart loop my aftermarket head unit at idle. If I was on the road driving, after the restart, it would stay on and continue to stay on until I was at a stop again. It wasn't getting the proper voltage due to the failing alternator. Just one thing to point out as far as my experience went.
If it's the latter, I would think it is due to a malfunction of the unit itself.
· Registered
Discussion Starter · #3 ·
So it keeps its settings, it just randomly turns on and off and I did recently replace my alternator. But I'll look into more. And like so it will at point stop until I restart my car and it starts all over again.
· Registered
Discussion Starter · #4 ·
It wasn't an oem alternator so idk if that would be an issue. Believe it was a 110 amp alternator I'll have to look.
· Registered
What I do know is that those OEM head units are very old at this point, and all of the little capacitors, resistors, and doohickeys start to leak/explode/fail. I would be wary of that.
I don't have an original radio, but if you are confident, you may be able to pull it apart, snap a photo, and see what kind of responses there are to failed parts in the radio.
1 - 5 of 5 Posts
