WHAT?
StealthQuebecer said:
yeah I know I have to keep same circumference...I think ill go with the new center line wheels...the 18inch ones that weight 11lbs would be good with something like 9.5 widht ill probably take
Did you say 18 x 9.5s that weigh 11lbs!?! I didn't know metallic hydrogen could be shaped into wheels
~ But really, where the hell did you see that?
Also - even the 700+ bhp cars run 9 or 9.5 inch rims ~ aside from looks, why do you want these - is there any special need??
You don't happen to know Dark Devil do ya?!?
He said he had 17 inch rims in the back, no not 17 by xxx, they were dubs, 20 x 17s really! And they only weighed 13 lbs - custom molded out of lithium, - but they cost their weight in cocaine!!!
He was a freak about weight reduction ~ but he had to be the first VR4 to run high-8s @ 170 mph on pump gas & winter tires
But then again he also had nitrous directly injected into the downpipe ~ bypass that stupid combustion chamber for the full effect! And a 20g turbo for each cylinder - bone stock fuel system off a Supra and bottom end off a Civic Si to handle all that power! + A front mount air-intake, a venom 400, Nology spark plug wires and the fuel mizer inline fuel magnet to align the fuel molecules!
- j/k ~ that guy is the resident bullshitter - also in Quebec.
