1 - 2 of 2 Posts
If an accident is your fault or if you back into something really good & if there is just invisible damage behind the bumper, why even fix it?
Is that only for the NEXT impact that might occur? Or is there some underlying safety issue?
If you feel safe with you bupmer the way it is (duct taped?), then i wouldn't worry about it. If you can hold off until it's someone else's fault then get them both repaired all the better.
1 - 2 of 2 Posts
