1 - 11 of 11 Posts
Money pit owner.
i'm replacing the gaskets that sit between the turbo drain line and oil pan. one side of the gasket seems to have a shiny side with a very thin o ring, the other side looks like paper. i've attached a photo of two gaskets so you can see both sides. anyone know if it matters which side of the gasket faces the oil pan?
Money pit owner.
ok, cool. I'm going to use a light skim of RTV this time around including the bolts themselves.
They put the o-ring on for a reason...the oring appears to be temperature activated. I would put o-ring towards pan, but thats just me. I don't think I've ever seen this discussed before, but I've often wondered the same.
If you don't know, the bolts are special. They use a captive aluminum washer to seal the bolt to drain flange connection. They are also one time use (although Ive used them 2-3 times without issue). No sealant needed if washers are not too deformed.
I have always done that as well as the chra is much flatter.
I still use rtv or it always seeps at the pan.
SDSU Alumnus
+2 for ring toward the pan and liberal amount of RTV
-sent from my Galaxy Note 9
Doc
Use copper gasket sealant spray, NOT RTV.. it works better with zero of the risks of RTV.
MSN, RN, FNP-BC, 66H
Money pit owner.
Discussion Starter #9
hmmm, I actually wonder if it's the bolt that is the spot where it's leaking. I have some tiny copper washers I can use, I can also put some rtv on the threads.
Money pit owner.
Discussion Starter #10
I think I actually have some of that copper spray that i bought many years ago. I forgot why I bought it. lol
Money pit owner.
Discussion Starter #11
I couldn't find the copper spray so i used a film of rtv on the gasket and threads. I will refill the oilpan tomorrow i check for leaks. I have to pull the oil pan in a couple years so i will replace the gaskets again anyway.
1 - 11 of 11 Posts
