The step-by-step from stealth316 was great.
There are only a couple of things I do differently.
When taking the tranny out I use an old tire next to the jack in case it falls off the jack. Better for it to hit the tire than the pavement.
Second, when installing the clutch I use brake cleaner to clean the surfaces one last time before installing.
Third, I install the tranny a different way.
I lift the car up as high as my jack stands will go.
Then I place the tranny directly beneath where it mates to the engine.
Then two friends help me. One person laying across the engine to line it up and lift. The other two lifting the tranny by jacking it up and armstrength.
We lift and clear the obstacles and then shove it onto the input shaft.
It is hard your first time, but it's possible.
Make sure you have extra gaskets for the downpipe and anything else that might be shot.
And soak everything the night before in PB blaster or something similar.
When you install use antisieze on threads, use new lockwashers, and use a good torque wrench.
I have two one for up to 75 ft/lbs and one for up to 150 ft/lbs.
You will also need lots of sockets. You need deep ones, short ones, swivels, extensions, 1/4 drive, 3/8 drive, 1/2 drive all kinds to make sets to reach into all the recesses.
p.s. The first time I took my tranny out I had to kick it off the engine by laying on the ground under the driver's side wheel and kick it to break it loose.
GOOD LUCK and drop me a PM if you have any questions!!!
