1 - 2 of 2 Posts
Lovbyts
I change the speedo gear in my 91 RT TT the other day and my oil presrue guage had not worked since. I took the battery back out and looked around but I can not fing anything unhooked. I can not see where the oil censor is either so I'm sure if I know where it was that would help.
Should be located behind your crankshaft pulley, mounted off of the oil pump housing (housing that holds your crankshaft seal) facing toward the back of car. Has a single wire going to it and it is easy to knock off, but space is a bit tight when you reattach.
Hope this helps,
Steve
1 - 2 of 2 Posts
