1 - 3 of 3 Posts
I have a '91 stealth es auto. and I can't find the speed sensors (speedometer dosn't work) anyone know where they are? I looked all over the trany, but no luck.
thanks, chad
D
Guest
Hey Chad! It is located right on the top of your trans, it is very visible if you remove the air intake or if you have already removed the resonator bottle, there is a room that large enough for your to see or reach to the speed sensor easily. Hope this helps.
Don94
Aghhhh
Well, it's a little tricky to describe this but I'll try. On your car's firewall, near your master cylinder, there should be a black cable comming through a black rubber grommet. This cable will almost immediately dive towards the bottom of the car and then snake towards the transmission. It screws into the top of the tranny using a grey/silver fitting. As far as the actual speed sensors go, these are internal to the transmission and aren't user servicable unless you want to tear your transmission out and apart. Good luck.
1 - 3 of 3 Posts
