Mine didn’t either and looking at pictures he posted in post #1 I don’t think his does either.If he has ABS. None of my FWDs did....
Hows the project going?I have not. Ill try to see if i can this evening.
I havent even attempted to try anything yet hahaha, been tired from work. Ill be attempting to pop the lugs out first after i make it home this evening. I do not have ABS on mine, 5 speed manual transmission. I forgot to mention that before.Hows the project going?
If you have enough room in any location to get a full length stud out, putting them back in is no problem. To install new ones you simply slide them in hole where you have room to do so, then use a spaced and lug nut to pull the splined area of lug into hub until head hits back of flange.After giving the hub a good look over, thanks to the guard I doubt I would be able to hammer out the old lug bolts and get the new ones in. Even more so for attempting to get the whole hub.
I looked at different spots and did find a likely spot that would have worked, but due to it being 25 years old and most likely never being taken apart after factory assembly i wasnt able to get it out with a hammer.If you have enough room in any location to get a full length stud out, putting them back in is no problem. To install new ones you simply slide them in hole where you have room to do so, then use a spaced and lug nut to pull the splined area of lug into hub until head hits back of flange.
Where did you get the knuckles from? Any idea if they'll just fit in without changing everything else with it?
How much that run you? That is if you remember. Been looking at some mods and upgrades for my slI got them from Hans / Ground Zero Performance in Pennsylvnia. I used vr4 knuckles, new bolt on wheel bearings, twin turbo calipers and new tt pads and rotors. Was a good upgrade swap in my opinion, definitely makes a difference in feel and they of course look better
I don't particularly remember. I think I paid somewhere around $150-200 for the calipers and knuckles from GZP. Rotors, pads and bearings were all from Rock Auto.How much that run you? That is if you remember. Been looking at some mods and upgrades for my sl
