1 - 4 of 4 Posts
Most of my cars it was LF, RF, LR, RR. Try to see what order the hoses run, and follow it, starting with the fronts.
G
You should always go rr,lf,lr,rf. An easy way to remember is start with the furthest brake, the closest, next farthest, next closest
G
Bleed the brake line in order of.......
RR, LF, LR, RF also as the manual says vehicles with ABS,be sure to filter/strain the brake fluid being added to the master cylinder reservoir tank just to be careful i guess so NO debris gets in or else it could/would damage the Hydro.Unit
1 - 4 of 4 Posts
