1 - 13 of 13 Posts
PSI is when your trying to get somones attention but not trying to get everyone to look yenno... PSSSSSSIIIIIIIIII!!:D ok i had my laugh for the day:p
Finally back!
PSI in relation to an NA is the amount of air in the tires. When it pertaining to a turbo it is the boost that a turbo is running.
it just means pounds per square inch but it can refer to pressure in ANYTHING, turbo boost pressure, fuel pressure, tire pressure, oil pressure, etc.
The Voice of Reason
That's misleading. As far as the tires are concerned, the pressure is not the amount of air that is in the tires, but the force that the air exerts over the inside area of the tire.
You forgot oil pressure too. ;)
As far an ANYTHING is concerned PSI ALWAYS refers to the pressure of the gas/fluid over the surface area of the container, not just for tires.
so if somone farts can that be measured in psi?:p
I'm pretty sure Summit has the new 5" monster Fart PSi gauge, comes with the free odor light.
The Voice of Reason
No kidding, really?!? :eek: But if you're talking about a different fluid and a different container, then you're not looking at the force the air is exerting on the inside area of the tire now are you? Hence, "As far as the tires are concerned."
:rolleyes:
1 - 13 of 13 Posts
