ttt
U can run a 75shot of nitrous for like $1500 (with all the bells and whistles). The supercharger kit alone is $4k, the turbo kit is $6k. You could get nitrous for less than the cost of installation on the turbo kit.nitroucf said:What Exactly would a S-afc do for a nos setup? I was under the impression that its would be on continually so either you set itt up for normal driving and run lean when using nos or set it up for nos and run rich while driving. Unless you used it for bigger injectors, then that would make sense. Personally I'd suggest using that money to run a supercharger or turbos..........no bottles to refill (can get expensive).![]()
Actually he left the bottle valve closed and the bottle heater on. The heater couldn't get a temp, and just kept heating and heating - until it blew his hood through a wall into his house (the maxima), and peeled his trunk back like a banana.nitroucf said:That car that blew up was due to lack of common sense. The gentleman installed his bottle heater blanket incorrectly so it was always on thus creating a high pressure in the tank. Next, he probably doubled up the safety blow off discs ( little metal disc which breaks if there is too much pressure in the tank) so it would hold more pressure. Combination of mistakes nearly killed him.
