Different ignitions have different strengths, so they require different gaps. Most modern fords use .052-.054. .048 is too small. It won't make a differene in how the car performs unless it's EXTREME one way or another. High compression and forced induction engines are more sensitive to gaps, as well as cars with weak ignitions, like old single coil GM and Chrysler. You can't take them over .035.
On a car with hard to reach plugs, go with the tightest gap allowed so the plugs will stay within spec as the electrodes wear.
