1 - 10 of 10 Posts
Senior Member
I am getting forged pistons and need to figure how much of a difference there are from the stock clearances to the ones ross recomends... so I was just wondering what the stock clearance was?
Senior Member
stock sized.. I felt it wasnt worth the money to bore.. my cylinder walls are in perfect condition so I will hopefully just hone and put in the new pistons... that is if the cylinder to wall clearances work out.
I'm looking in the service manual and it says the clearence Piston to cylinder is 0.03-0.05mm (0.0012-0.0020 in) Is that what your looking for
Senior Fanatic
Not according to Mitsu's engine overhaul manual. The Service Manuals say what 6g72tt quoted, but I would trust the overhaul manual first!
http://www.twingles.com/manualcd/dsmgift/
It says that SOHC and DOHC piston-to-cylinder clearance is 0.008-0.0016", all years.
Your probably safe using the overlap region, 0.0012-0.0016". :)
Sorry brainfood, I didn't know those numbers might be incorrect, I was just trying to help you out. I wonder why they would put the wrong numbers in the service manual?? It's good we have our father angel of 3si (Jeff Lucius)
Caution: If you go to an aftermarket forged piston, you'll need more clearance than listed in the service manual. Ross will recommend ~.006" for moderate power and up to .010" if you boost high and use nitrous.
If you build your engine outside of the aftermarket manufacturers recommendation, you may run into problems.
Also, an oversized piston is almost always the recommended way to go with a bore and hone used to obtain the desired clearance.
1 - 10 of 10 Posts
