1 - 7 of 7 Posts
Wanted: Need used transfer case for my '91 TT
Hey guys, I need a used transfer case for my '91 TT. Also does anybody know off hand how much a new one is roughly? Also, does anyone know how hard it is to install? It looks fairly simple to do, but I want to make sure b4 I start tearing into it. Thanks alot.
Tim
'94 T-62 Supra
'91 Stealth TT
Member
By "frt" do you mean front? The front differential is inside the the transmission and is not sold separately. Frank at Kormex (www.kormextrans.com) might have a used one to sell you. If you are talking about the REAR differential, I have one of those for sale from my 1992 Stealth turbo since I have been doing the six speed conversion recently. Let me know if you are interested.
BCTURBO
Thanks for the reply. I meant that I needed a new transfer case. I don't know why I put frt diff. I'm an idiot. The post has been edited. Thanks and let me know if you have the transfer case.
Thanks, Tim
Member
Yes, I also have the transfer case left over from my conversion. Mine is a 25 spline though. I think most of the 1991 transfer cases were 18 spline. Count your splines and if you have a 25 then we can make a deal.
Discussion Starter #5
Well, I have not taken mine off yet, and don't want to until I get a new one first. I thought they didn't switch until '94? Does anybody know for sure if his '92 transfer case will work in my '91?
Thanks, Tim
Member
They DID change the transfer cases in 1994- again. The early first gens had 18 splines and they changed over to 25 spline at some point. The 2nd gen 6-speeds use a different 25 spline transfer case. You may be able to tell which one you have by calling a dealer and giving them your VIN number. Otherwise you will have to take the case off and count the splines. It is not too difficult to take off. Try calling a Mitsubishi dealer first though.
Discussion Starter #7
Ok, I will let you know. Could you please give me a private e-mail with your phone # so that I can talk to you a little more about this. I would greatly appreciate it. [email protected]
Thanks, Tim
1 - 7 of 7 Posts
