Hi all,
Long time lurker here. I have tried using the search feature. Need help!
So I got a 1996 VR4 with about 145k miles. Ever since I bought it, it has had an awful vibration from the rear of the car only when accelerating from about 15-45mph then its smooth all the way to highway speeds (70+). It does not seem to be engine speed related..vibrates no matter the gear. What all do you guys suggest me to check?
Things I have done:
New PST 2pc driveshaft (with carrier bearing)
Alignment
New tires
Balance tires multiple times
Verify wheels arent bent
Done 120k maintenance
Changed fluids
New front tie rod inner and outer
New front right axle
Previous owner replaced these (from reciepts they gave me):
Front drivers axle
"Complete rear drive line assembly"
Thanks in advance
Things I have done:
Alignment
New tires
Changed fluids
Front drivers axle
Thanks in advance
