Hi, My friends @white93gt @box @beegeezy @Chang oil ,
My new "four seasons" compressor arrived today, the looking seems pretty close to the OEM one but still has some differences, And I got some questions also.
1. it comes with two connector set, my car is 95, so I assume I will need the 5 pins (in the first pic), is my understanding correct?
2. you could tell from the second picture, that one of the connectors on the plate which is near the opposite side of the pulley is very different from the OEM one, the new one can not be called a connector actually, it is a hub with two fixed wires on it, and there is a "Female" connector on each wire (A and B from the Sec pic). That 5-pin connector has 3 spare wires on it, two of them are male (C and D), so they obviously supposed to connect to A and B those two Female connectors from the compressor plate. But the question is which one should connect to which one? or does not matter?
3. you could see there is a black panel on the end of the compressor. What is that? Is that something for dumping the oil in it? If so, what is the torque spec for it when refill and install back?
4. The last one, you see there is a label said "This compressor pre-charged with 3 oz of oil", is this means, I don't need to dump the oil, then I can hook it up it and use it directly?
Thank you so much!
Thank you so much!
