1 - 1 of 1 Posts
The antenna on my 93 TT is not working and the mast is cut off. When I turn the radio on, it sounds as if the motor is turning and making nose. But there is no wire inside and the mast is cut/bent off, nothing comes up or down. I bought an universal unit and try to install it. There are 4 wires:
1. thick antenna wire (can be directly connected to the wires coming out of the head unit)
2. black ground wire
3. white wire ???
4. red wire ????
I think that the red is the power source (+, it's got a small fuse in the wire) but not sure what the white one is. I am not sure if the factory wires are color coded the same way so I can just splice the same wires? Any idea?
1 - 1 of 1 Posts
