Alright, got a new one for all of you. Background info, 1992 GTO MR Rhd, bad ecu and attempted to replace with a usdm replica with same part number. No dice. Now I’ve bought a jester chrome ecu, version 3, with tactrix openport 2.0 and cable. All programs function as they should on other cars and the openport works fine on other cars as well.
the issue
After installing the ecu and routing the black and red wires to the back of my obd1 port, red wire to pin 2 and black wire to pin 6. I plug the obd1 to obd2 adapter into it and when I check pin 2 and 16 on the obd2 I get 12 volts. So why is it that when I plug the openport into it it doesn’t light up and fails when you attempt to load a flash into the ecu and evoscan says less than 5 volts detected? I’ve been unable to find any type of solution even after contacting tactrix and chrome. Has anyone encountered an issue like this before? I’ve checked the fuses and everything is good. All connections are secure. All plugs to the ecu are solid.
the issue
