1 - 20 of 31 Posts
SoCal3S Member
Don't forget to leave me some +1 REP ... THANK YOU in advance!!
Well This MY tutorial that i made and them updated.......
I got the steering wheel off ebay!!! :D
(DISCLAIMER - I AM NOT LIABLE FOR ANY DAMAGES TO YOUR AIRBAG SYSTEMS, YOU , OR YOUR CAR )
Here Are some pics of my car... with my EVO wheel.
SoCal3S Member
Discussion Starter #2 (Edited)
Here are some pics of my tutorial.....
Tools you will need......
this is the under side of the EVO Steering Wheel .. you will have to take a part to CUT and Weld the RING / HUB
take the plastic ring off with a FLAT head Screw driver or a knife like i did...
Remove both screw that are located on each side... to remove the AIR BAG
Remove the three screws to remove the plastic cover
I Cut the Plastic cover like so.... now it can fit the BIGGER 3000gt RING / HUB
Now the HARD part of the project.... CUTTING or Removing the weld of the ring / hub to replace with the 3k one.
i welded the OUT SIDE AND THE INSIDE just to be safe!!!!
This is what you should have at this point......
SoCal3S Member
Discussion Starter #3 (Edited)
Start Putting all back...
Plug The Horn.. NOW that AIR BAG i am still looking to connected ;-)
put the air bag plastic cover back on and you are done!!!!!
Thank you all for looking at MY tutorial....
here is the link where i got the info for the EVO Steering Wheel custom swap...
EVO Steering Wheel in a DSM. - DSM Forums
DON'T FORGET TO +1 REP Me IF YOU LIKE OR FIND IT INFORMATIVE... THANK YOU!
Question Section:
1) Would the Air bag Still work?
1 Yes it would... you just have to modify the connection... like so....
2) Can I Keep my cruise control?
YES! here a pic so you can get a idea to keep it.
3) Is the EVO wheel smaller than the STOCK one?
YES! alot smaller... and it feels WAY better....
any more questions??? ill update this section
[/COLOR]
I'm confused.
I thought the Evo airbag system and 3000GT airbag systems aren't the same (the Evo being a two-stage airbag system IIRC) so it won't work?
If the airbag would still work, then that is truly awesome and something I will be attempting in the near future.
Great tutorial btw.
Retired
Nice!!
I have a quick question since I've never had my steering wheel off before. Do our stock steering wheels only go on one way (aka do they have a "goofy" spline), or do you have to mark the splines so it goes back on the correct way, so you don't accidently put the steering wheel back on off centered?
I like boost
This is great! At 6' 4" I have always found the steering wheel to be unnecessarily large. Made heel/toe action a real PITA during autox.
+1!
Retired
all questions answered at the bottom of my tutorial!! :D
You don't have to add this to the bottom of your tutorial, but can you answer this one for me:
Nice!!
SoCal3S Member
Discussion Starter #15
well.... it has grids... so you can put the steering wheel sideways...
but no problem just move it around till is strait... it took me 2-3 tries to get it back to place i wanted... which is real center...
Retired
Huh, no kidding. I would've thought it would only go on one way or at least have alignment marks on it.
Thanks for the info!
SoCal3S Member
Discussion Starter #18
the guy that did the thread back in a 2006 is a loser!!! hahaha i guess he has no creativity...
you tell me if the EVO Steering wheel FITS NOW!!!! :muahaha:
and to plug the AIRBAG there is no direct bolt on so you need to connected as showen in the pics.... once i TAKE MY BABY TO A CAR ELECTRIC i will ASK HIM AND POST updates on how to connected.... and them i will ask fo MORE REP hahaha :muahaha:
HEAVILY self medicated
wait we can ask for rep on this forum??????
1 - 20 of 31 Posts
